When plugins are set to ask to load disabled plugins in V6, the popup doesn’t get focus and stays behind all other windows when I start an additional Rhino instance from an open Rhino.
In V5 and Win7 Pro, it popped up to the top - was this change intentional? I often run several instances and have loaded some plugins only when needed because they slowed startup and used a lot of extra RAM.
Maybe those issues are no longer the case in V6. Vray and T-splines were the plugins I avoided loading unless needed. Now running Win10 Pro and Rhino 6.13.19058.371.
Thanks!
