I want select all these shape as multiple curv in grasshopper and need to connect to list item and want to select shape which ever I want. But problem is while selecting the desired shape through list item single line shape is only getting selected as whole multiple curv shapes are getting split into single curve. I cant select whole shape 2 and 3 in once. How to slove.
BTW: In fact and with regard the general case you need an other type of clustering called HAC. Given any collection of randomly (jittered) sampled curves … spot the branch dimensions (blue) per root/child cluster(s) and what have to tell you about what contains what (and what is contained in what):
@DavidRutten any help on this
I shared my idea above
But you didn’t post any code/geometry data for us to work with.
- Attach minimal versions of all the relevant files
If you have a gh file you have a question about, attach it to the post. Do not expect that people will recreate a file based on a screen-shot because that’s a lot of pointless work. It’s also a good idea to remove everything non-essential from a gh file. You can use the Internalise Data menu option to cut everything to the left of a parameter:Simplifying a Grasshopper network
If you are referencing curves or breps or meshes from Rhino, you can also internalise them so you won’t have to post a 3dm file as well as a gh file. If you’re unsure whether all the relevant data is internal to the gh file, try opening it in an empty Rhino. Does it work? Good. No? You’ll need to internalise more.
- Include a detailed image of the file if it makes sense
If your question is about a specific (group of) components, consider adding a screenshot of the file in the text of the post. You can use the Ctrl+Shift+Q feature in Grasshopper to quickly create nice screenshots with focus rectangles and embedded viewports such as this:
I post code now
query.gh (8.6 KB) I attached now any help is possible sorry previously not attached @Joseph_Oster
You have things plugged in incorrectly, look closer at my image or just download the file.
Sorry @Michael_Pryor as amature guy I made silly mistakes.
any suggestions you have learn all these data management things.
