Hie,
I would like to divide a list of points based of its belongs to a rectangles. I have done it but selecting one of the rectangle. I like that do it in the three rectangles automatically. Could you help me?
Regards.
unnamed.gh (7.0 KB)
Hie,
Regards.
unnamed.gh (7.0 KB)
Use the output of the point in curve as the input to a cull pattern
Use the Point In Curves component (you’re file uses the Point In Curve component).
The Index output gives the index of first region that contains the point.
-Kevin
unnamed[fixed].gh (8.8 KB)
Thanks so much @adel.albloushi Adel and @kev.r ! I check it and it works.
And…If we doesn´t know the numbers of rectangles , do you know how could we do the explode tree?
Regards.
you’re welcome. it shouldn’t matter how many curves there are
you’ll have a list of curves like this
c = [c1, c2, … , cn]
and a list of lists of points like this
p = [ [pts_c1], [pts_c2] , … , [pts_cn] ]
and they will always be in order, meaning that for any index i, p[i] is list the points inside the curve c[i]
so, it really depends on what you want to do with the curves and points should dictate how to manage the curves and lists of points
check this example
unnamed[fixed][example].gh (17.5 KB)
i included an explode tree so there’s a visual way of selecting p[i]. if you have variable number of curves, you can always right-click on the explode tree and select match outputs
