Could you help me please?
I would like select several curves from list (for example 1, 2, 6, 11, 45 etc.) but as shown below I can select only one curve.
Thanks for advice
Thanks for advice
flatten the contours list and use list item component
If you want to maintain the DataTree path information you just have to use the proper mask (or masks) to split the tree.
240318a_split_datatree.gh (11.6 KB)
Info. here on constructing masks:
-Kevin
right click on your mask panel panel and select multiline
then double click to edit, and insert a new mask
for example:
{0; 0; 0; 2}
{0; 0; 0; 13}
{0; 0; 0; 45}
