Hi @DanielPiker
Linkage works pretty well, i recreate this and i am sure you can make it better
I use group points than assign a goal to each group, maybe this can be done by a single component.
linkage new test.gh (27.1 KB)
Hi @DanielPiker
This can also be done with just Length and Anchor:
Great, thanks @DanielPiker
I will test more complex shapes
You can use AnchorXYZ to prevent movement of a point in some axes. So here you’d set X & Y false and Z true
Thanks, i choose OnPlane because of plane input which more useful in the space.
I hope you add an option to limit point movement in all directions by distance ,if this is not already available
