You can create a frame from the line segment and orient geometry using this like so:
strandbeest_orientgeometry.gh (16.8 KB)
(Here I’ve created the geometry from the lines so the order matches automatically, but if you want to make it some other way in Rhino, you need to make sure to reference it in the same order as the line segments)
