Link together two brep projections
Hi, so I just started to use grasshopper and drawing link for Tekla. I have Brep from beam and two Brep projection borders, one for top view, and one for front. The question is, how to use points that are gathered from front view into top view?
Recategorized to Grasshopper / Tekla
so maybe an easier question, i have a beam, how to make Brep Projection Border on it in X Z plane? by default it goes to X Y plane
Depending on what you want to achieve, you can use Make2D or convert the beam into a mesh and use Mesh Shadow. If you fail to do that, please provide either a Rhino file with the brep geometry or a Grasshopper definition with the brep internalised.
You just have the mapping for the coordinate systems wrong, it seems.
If you could internalize the data and attached the script that would help.
@Grzegorz_Olszewski might also be able to comment on this, since he built the drawing link. Great job on that btw!
