Problem with projecting a curve onto a brep
Hello everybody.
I’m trying to obtain some sections from a manipulated hull surface. I have created series of lines and been trying to project them onto the surface. But probably since i have created a surface by joining 3 seperate surfaces together, some of the lines are not projected on the final surface.
How can i manage to solve this issue? I am adding pictures and also rhino & grasshopper files. You just need to set the surface in rhino file to initial surface commands in grasshopper to run the code. Thank you.
Tez basis1.3dm (62.5 KB)
Ghforum1.gh (21.8 KB)
Ghforum1_re.gh (26.1 KB)
Thank you so much
