Hi
I’m working on gh def that contains a list of images linked with a “pulldown” component of Human UI plugin.
When I select an image from pulldown menu it compare in a view.
This is a list:
This is a relative dropdown menu from “Human UI” plugin:
I need to assign to each menu voice a specific number.
For example: i want to assign at menu voice “Anteriore Destra” the number 37 and at menu voice “SINISTRA DESTRA” the number 12, all when i click on this menu voice.
I want that this number appears in several “param” components.
Can you help me to understand how obtain this function?
Thank you
Thank you so much @efestwin I’ll try to do it.
I’ve another question and I think that you could help me…
I’ve a problem with view a data in “param” component in Human UI Window.
I’ve a PARAM component in which it’s a value that derives from a dynamic measure taken with slider on a 3D objetc.
When i try to create a “Label” in Human UI in which insert this value I obtain this error:
1. In general, it’s not a good idea to drive the creation of elements with the results of a value listener. Instead, use the value listener to drive a “Set” operation, from the UI Output tab, to update the contents of an existing element in the window. Otherwise, every time something in the window changes, triggering your value listener, the entire window needs to be re-generated. This can create the appearance of a "freezing" behavior. See the example files for more information on the appropriate configuration of “Create” and “Set” components in Human UI.
This is a velue that I need to “render” in UI Windows:
I have only used Human UI once before, so I’m not an expert here. But I interpret it like this:
what you are currently doing: Value from Param >> create Label
how it should be done ideally: create blank label >> Set value of label to value of param
There should be a component in Human UI that is called “Set” and sets value of a label or other object. But I’m doing this or if my head so no guarantee. I hope it’ll help anyway
