i have problems with linetypes.
First of all - is impossible to import additional linetypes:
Second issue:
If i have own temlate with more layers and more linetypes then opening linetype dialog from layers panel takes about 10 second: (wait for it…)
If i use standart template with standart layers and standart count of linetypes, there is no problem…:
Wait, i lied. I can repeat the performance issue when opening from the Layers panel. I just watched your video. Thanks! I’ve just found and fixed the linetype opening bug. I’ll see if I can improve that preview speed. Do you have the same issue when viewing the linetypes on the Linetypes panels?
