I’m having these weird linetype problems. They don’t show correctly in the modelspace, paperspace and even when i print them to pdf. Some look good, other don’t. as shown in the image below.
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Primary display and OpenGL: NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 1-22-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.40
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-22-2021
Driver Version: 27.21.14.6140
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\ProgramData\McNeel\Rhinoceros\6.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
Hello - if the curve is composed of multiple joined sub curves, you can try LinetypeDisplay and set that to usse ‘PatternBySegment=No’ - does that help?
These are single nurbscurves. For testing, I did rebuild them into polylines and changed it to ‘PatternBySegment=No’. But it didn’t make any difference.
I did noticed the following:
Once i change the linetype scale from 200 to 1000, the linetype viewed correctly. See image below
I have a feeling that once a curve gets TOO long with a relative small pattern (for instance when a curve has many many dashes) Rhino seem to struggle to preview the pattern.
@pascal
Do you have any thoughts on why rhino can’t preview and print these linetypes correctly? many thanks!
I am also having this issue with my Rhino 7 on mac. Have there been any breakthroughs on this? I think @mse is correct about the length of the lines. I am working on a large landscape project and my contour lines are very long. The longer they are, the more inaccurate their display is (similar to the examples shown here).
