Hi, I have an issue with LinetypeDisplay command. I created a linetype as picture below and draw a line with it. I’m expecting when I toggle LinetypeDisplay command and change DisplayLinetypes=No, the drawn line should be “Continuous” linetype, but the only pattern segment is correct but width is not changing.
I saw RH-81101 also talking about similar topic but not sure is it same issue.
Linetype Settings
LinetypeDisplay > DisplayLinetypes=Yes
LinetypeDisplay > DisplayLinetypes=No
