Query Model Linetypes skips "Continuous"
The default baked linetype (when none is provided) appears to be Continuous.
However the Query Model Linetypes (Linetypes) never finds it or show it.
Despite the other linetypes working as expected
and the linetypes existing in the default 3dm templates.
and being discoverable with the Model Linetype parameter
Is this a bug or by design?
Same here.
This is fixed in 8.11
Thanks @kike. I marked this as the solution, however now I’m confused. I was having the problem in 8.8.24170, and i just checked again and the problem is still there.
System information below:
Rhino 8 SR8 2024-6-18 (Rhino 8, 8.8.24170.13001, Git hash:master @ c3cc7c123163b65d85b517aff795627d5b12166b)
License type: Commercial, build 2024-06-18
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.20
Computer platform: LAPTOP  - Plugged in [100% battery remaining]
  Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 7-11-2023 (M-D-Y).
        - Secondary monitor is laptop's integrated screen or built-in port
        - Windows Main Display attached to adapter port #2
  Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 12GB, Driver date: 3-9-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.79
Secondary graphics devices.
  Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
    > External USB display device with 8 adapter port(s)
        - There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
  Safe mode: Off
  Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Render version: 4.6
  Shading Language: 4.60 NVIDIA
  Driver Date: 3-9-2023
  Driver Version: 31.0.15.2879
  Z-Buffer depth: 24 bits
  Total Video Memory: 12 GB
  C:\Program Files\Rhino 8\Plug-ins\Commands.rhp	"Commands"	8.8.24170.13001
  C:\Program Files\Rhino 8\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp	"Rhino Render"	8.8.24170.13001
  C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp	"RDK_EtoUI"	8.8.24170.13001
  C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp	"Snapshots"
  C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp	"MeshCommands"	8.8.24170.13001
  C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp	"IronPython"	8.8.24170.13001
  C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp	"RhinoCycles"	8.8.24170.13001
  C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp	"Grasshopper"	8.8.24170.13001
  C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	8.8.24170.13001
  C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp	"3Dconnexion 3D Mouse"
  C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp	"Displacement"
  C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp	"SectionTools"
Hi @dharman,
This is fixed in Rhino 8 SR11 that will be released today.
Please update Rhino tomorrow to see the changes.
oh i misunderstood. I thought you were saying it had been fixed in 8.8.11.
Unfortunately i will need to wait for out IT department to approve a new version before i can use it, but that’s my problem not yours. Thanks!
@kike If I see correctly what this is about, then it should be fixed that searching with a wildcard for “continuous” should return the correct line type.
I am on 8 SR 23 and it’s not working:
Am I missing something? Is this a regression?
If I just list all the line types then Continuous is there, but in brackets!?
Hi @seltzdesign,
“(Continuous)” linetype is a special linetype that is always available and its name is translated when Rhino runs in Spanish, French or any other language supported on the UI.
In order to allow you reference this Linetype in a way that works on any language and does not collide with an existing Linetype in the document, this special linetype is called “(Continuous)”.
The parenthesis are on purpose because is not possible to name a Linetype like this.
Same approach is used for the default material that is called “(Default Material)” on any language.
This way you can run a .gh file authored on any language on a Rhino that has its UI on any other language without any conflict.
I see, thanks for explaining.
Does that mean the other defaults like “Dashed” or “Dots” would break on a machine having GH set to another language?
