Just to highlight a minor bug. LineTypeDisplay which should toggle linetype display does not work on both platforms on V8.
Given the rate at which fixes and changes are being made in various Release Candidates and Releases it would probably be very helpful to specify exactly which RC you are having the issue with.
Thank you for the advice.
Hi Sean -
Thanks, I’m seeing that here → RH-81101 LinetypeDisplay: DisplayLinetypes option does not work
Thank you Wim
RH-81101 is fixed in Rhino 8 Service Release 6 Release Candidate
