LineType Taper not printing in Vector
When printing PDF of a Rhino layout, I see that the taper applied to a linetype is correctly represented in the raster output but not in the vector output.
Am I missing something @mary?
arrow.3dm (140.3 KB)
arrows_raster.pdf (1.0 MB)
arrows_vector.pdf (1.8 KB)
Configuration.
Rhino 8 SR12 2024-10-8 (Rhino 8, 8.12.24282.07001, Git hash:master @ 2f42167325d83e0da0f3fe08e796c2b26e602bc5)
License type: Commercial, build 2024-10-08
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Primary display and OpenGL: NVIDIA RTX A4000 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.76
- Secondary monitor attached to adapter port 1
Primary OpenGL: NVIDIA RTX A4000 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.76
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-23-2024
Driver Version: 32.0.15.6076
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\pollination\plugin\8.0\Pollination\ModelEditorRhinoPlugin.rhp “ModelEditorRhinoPlugin” 1.16.9.0
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\WB_RHTrack (f1b547e5-c3af-478d-84ee-6804536a8bb2)\1.0.7346.25956\WB_RHTrack.rhp “WB_RHTrack” 1.0.7346.25956
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.4.3.0
C:\Program Files\pollination\plugin\8.0\Pollination\Environmental_Analysis.rhp “Environmental Analysis” 0.0.0.0
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.24138.1238
C:\Program Files\pollination\plugin\8.0\Pollination\Pollination.RH.rhp “Pollination.RH” 1.52.12.0
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\ElefrontProperties (5db9285b-b408-41e2-b815-ed6ad84fd4a9)\1.0.0.0\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\nycdvc\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\WombatRhino\1.0.5.17\WombatRhino.rhp “WombatRhino” 1.0.5.17
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.224\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.224.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.52.12\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.52.12.0
C:\Users\nycdvc\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Wb.ModelEstablishment.Rhino\1.1.3\Wb.ModelEstablishment.Rhino.rhp “Wb.ModelEstablishment.Rhino” 1.1.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Users\nycdvc\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.12.24282.7001
C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp “PDF Export” 8.12.24282.7001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.12.24282.7001
@scottd any idea why this might be happening?
Hi @Devang_Chauhan,
Sorry for the delay.
It looks like a bug.
I can repeat it and have logged RH-84536/Taper-Linetype-Not-Vector-Printing
You can follow the progress on the bug.
And we will also post here where there is fix.
Thanks for the file and for letting is know.
Sincerely,
Mary Ann Fugier
RH-84536 is fixed in Rhino 8 Service Release 14
