Hi, I can’t determine why the linetypes are not showing correctly in my drawing. I have consulted many videos on the matter and the options are still not working for me.
Also, it would be nice to have an interactive menu like in Adobe ‘Illustrator’, with all the available options and an apply button to control the size without having to go into properties and press the ok button for every iteration.
The global linestyle scale is controlled by this setting here. Which is what I use so all the linestyles get scaled by the same amount. If you want to vary a particualr object from another you can use the setting under the properties of the element/crv.
Thank you,
Indeed that’s a valuable setting, but my issue persists with that file but with a new file its
works fine:
I have no clue about what setting could cause this. I have set it to wireframe mode, and verified that _LineTypeDisplay was enabled and the units is in meter to match the new file I tested.
