I am working on a script that has a custom getpoint function, where the drawing function has a patterned line using the function: “DrawPatternedLine(self: DisplayPipeline, from: Point3d, to: Point3d, color: Color, pattern: int, thickness: int)”
Is there a way to set the linetype scale with this? Thanks.
I don’t know. The code to calculate the pattern curves is expensive to run, which is why Rhino does not dynamically draw curves with assigned linetypes.
