DisplayPipeline for linetypes
Hi I’m trying to draw a custom linetype pattern using RhinoCommon’s DisplayPipeline.
I can only find the DrawPatternedPolyline ( https://developer.rhino3d.com/api/rhinocommon/rhino.display.displaypipeline/drawpatternedpolyline?version=8.x )
but the output is bad, it looks like some patterned paper is overlaid on my screen.
I would wish a method in the displaypipeline to draw a line with actual linetype (like the ones we see in the layer table) which would be scaled using linetypescale and all other real lines.’
EDIT: Looks like i might be able to tweak the Pen in here, https://developer.rhino3d.com/api/rhinocommon/rhino.display.displaypipeline/drawcurve
Create a DisplayPen instance with whatever pattern information you want and use this when drawing curves.
https://developer.rhino3d.com/api/rhinocommon/rhino.display.displaypen
Thanks for prompt reply!
