Lines will not appear in rhino 6
Hi guys i just installed rhino 6 on my desktop at home and it works perfect. i just installed it on my laptop so i could use it at uni, and when it is installed, and i use it, no lines appear, as in i draw a rectangle it wil not show up. if i highlight it it will be selected and gumball appears and it is only as a dotted line, then when i click off it it will now dissapear. a solid box appears but with no edge lines. please help as i need to use my laptop at uni and this is not working at all!
Please post the result of Help \Rightarrow System\;Information
Rhino 6 SR4 2018-5-4 (Rhino 6, 6.4.18124.12321, Git hash:master @ 396f4c3420cadef29ac36e4307c8f98f7753c933)
Licence type: Educational, build 2018-05-04
License details: Cloud Zoo. In use by: Anthony Peev ()
Windows 7 SP1 (Physical RAM: 7.9Gb)
Machine name: PEEV-PC
GeForce GT 650M/PCIe/SSE2 (OpenGL ver:4.2.0)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.2
Shading Language: 4.20 NVIDIA via Cg compiler
Driver Date: 9-6-2012
Driver Version: 9.18.13.637
Z-Buffer depth: 24 bits
Total Video Memory: 512 MB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
Before any else please first update your driver. According the Nvidia website the latest driver for your GPU is GeForce Game Ready Driver | 397.64 | Windows 7 64-bit, Windows 8.1 64-bit, Windows 8 64-bit | NVIDIA (make sure you check the Additional Information tab on that page).
OH MY LORD! THANK YOU KIND SIR!!!
you are an absolute life saver! i can not thank you enough!! thank you thank you! it worked. i knew it had to be something small because everything was fine except the display of lines. thank you so much! problem solved!!
Glad it worked for you. Many happy drawing hours wished!
