The issue is lines the lines in PDF output:
I see I am not the first to encounter this:
(upload://gI7ql0fcYMelI7iVkilpiFfP8eV.png)
I have tried the PDF export but is there any way to get it to center the extents?
it is… it’s captured the extents of the scene. there is something somewhere that is causing that alignment.
if you don’t want that, use window and draw where you want it to capture.
