I’m looking to create a number of lines that should use points belonging to a data tree of the same index. e.g. point 0 of branch 0 with point 0 of branch 1 etc.
I’ve completed what I want to do but I am currently manually splitting the branches with “Explode Tree”.
The problem is if the number of input curves changes which affects the end points of the lines, I would need to add or remove branches manually to create the lines. I would like to remove the manual element of this exercise.
Any help would be much appreciated.
Test.gh (15.2 KB)
