Whenever I try to print to export the file to a PDF, the hatches come out with these lines on them
Hi Dale,
Can you type in SystemInfo into the command line and post the results here?
A sample of the file would be helpful as well, thanks!
A little underpowered in the GPU but system info look OK in that regard.
If you zip the file you can upload here.
https://www.rhino3d.com/upload
You might also update your Rhino to the latest service release 7.17…
Oh, wait, you can’t, you’re using a cracked version… ![]()
I think I fixed that in a recent service release.
