Hello, I’m using Rhino 8, Once I extrude any surface I can’t draw or snap on any edges, curve or any surface. the snap selects the point on the plane.
Hi -
That sounds like you have Project turned on in your OSnaps.
No, it is not turned on. All the settings are in default mode.
Then we’ll need more information.
Please provide both the output of the Rhino SystemInfo command and a 3dm file that we can take a look at.
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Evaluation, build 2024-11-12
License details: Cloud Zoo
Expires on: 2025-03-11
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in
Primary display and OpenGL: Radeon RX 580 Series (AMD) Memory: 4GB, Driver date: 3-30-2023 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 22.20.27.09.230330
> Integrated accelerated graphics device with 7 adapter port(s)
Primary OpenGL: Radeon RX 580 Series (AMD) Memory: 4GB, Driver date: 3-30-2023 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 22.20.27.09.230330
OpenGL Settings
Safe mode: Off
GPU Tessellation is: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 3-30-2023
Driver Version: 31.0.12027.9001
Z-Buffer depth: 24 bits
Total Video Memory: 12000 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
Hi -
-w
Rhino practice.3dm (1.4 MB)
Hello, so basically I can’t draw or select anything on the Z axis.
Your file looks/works fine here. I would suggest you update your video driver in any case, but not sure that will solve the problem.
Hi -
Can you provide detailed steps about what you are doing? Which command are you running? Can you post a screenshot of the OSnaps? Perhaps turn on the OSnap tooltip and make a screen recording?
Let’s say if I draw a box or a rectangle. and then if I select the line or polyline line command to draw on the surface or curve of the box the snap actually goes through the box and selects the grid on the surface of the CPlane. It’s like it is not detecting the box.
Hi -
That’s what the Project option does.
In the Rhino Options, under Modeling Aids → Snaps, check the Project object snaps to CPlane and Project object snaps to CPlane in plan parallel views options.
Thankyou.
Okay, so if I select a plane I can make a line on the Z axis. but if I select an object and try to place it on another object it won’t select the other object or any point of the object.
Like I can’t stack an object upon another like if I had to make a staircase.
Run Move, select the one object. At the Point to move from prompt, snap to a corner of that object. At the Point to move to prompt, snap to a corner of the other object.
At which point does that not work?
the point doesn’t snap to anything on the Z-Axis or anything above the surface. it just selects through the object. I have turned on all the boxes you have asked me to on Snap and Project.
Make sure Project is turned OFF.
yup, still nothing.
Okay so here I’m trying to mirror the Curve on the object but for me to select a reference point it won’t select any point or line on the surface, instead it goes straight through the surface.
