I have been having an issue as long as i can remember with line types in Rhino, usually, when i go to plot my well-placed line weights are usually in disarray because of this feature. Typically, I’m so close to deadlines that plotting and sending is a must.
I am attaching a few screenshots to convey this message & idea. This is for hidden, phantom & intermittent line weight scale
Rhino, has a model scale option to see your liveweight scale as you draft, but when you go to plot its not what you see on the screen. I just recently realized that you can scale the line weight in the property tab and it actually scales the line scale and prints accordingly, not just as a view.
This feature seems important enough to be included in the layer options so that we can make hidden lines larger or smaller, depending on the element, currently that is not possible with the line type scale, if you have to do it for each line.
Why can’t we have a layer tab for linetype scale as well?
PLAN SET A - S-2 linetype scale issue.pdf (129.6 KB)
