(file removed at users request)
Kyle,
Thank you so much. I’ve been working on this unsuccessful for days. It was stressing me out. I’m going to try to fix it from your file and let you know how it goes.
Thanks again,
Jim
happy to help-
Kyle,
Still getting the same error message. I opened the file to see if it would work. I need to learn how to do this, because I have another file that will need the same fix.
Thanks,
Jim
(attachment removed at users request)
Yes, I took it off because we weren’t using that part of the drawing.
James, when you send a file to have looked at and you don’t want the public to see, send it to tech@mcneel.com. If you send it to this forum all will be able to see it. —-Mark
I wish I knew that earlier. Can you make private the files I’ve sent?
removed all your attachments and the files I sent you in return. Let me know of you need anything else removed,.
you are welcome to continue this privately at tech@mcneel.com
Hi James -
You should probably use the web interface for the forum instead of your email application. I notified you of that fact when you posted that file.
Kyle,
Thank you so much. I’m going to try another way, download the file with other supported types and see if that works.
