Line caps in rhino
Good afternoon¡
I am triying to create some 2D plan with rhino, but I dont like how thick lines looks like. Could I make the end of those lines rounded or at least join them? I attached some images, one of rhino and another one of autocad, that makes what I was triying to do
This is the Rhino file
This is what i am triying to achieve, it doesnt have to be rounded, but at least closed i think…
thanks a lot
Javier
This has been on the wishlist for a long time but has not been developed yet.
https://mcneel.myjetbrains.com/youtrack/issue/RH-2285
Sorry.
Thanks Jhon¡ I think that it is very important cause if not…we should finish the drawings in other softwares that are much worst than rhino¡
@stevebaer
Bump
Rounded end caps have been implemented in SR7 which will be available on Tuesday as an initial release candidate.
I think this has been tuned up - I think…, if I’m thinking of the right thing… hold on a bit, I’ll look for the bug.
item…
oops. never mind - I say what Steve said.
Hey i found a very stupid solution…if i go to linetypes and i change the pattern insted of 1 to 2 or 3…suddenly the corners became rounded :rofl:
Hey Guys, I’m using Rhino 7 and wanted to know if the end cap issue has been addressed. I’m getting squared off and want rounded. Thanks!
Hi Ian - this is what I see in V7, with PrintDisplay on
I take it that is not what you see?
Please run the SystemInfo command in Rhino and copy/paste the results here.
Hi Pascal,
Thanks for your response. I should have been more specific…the lines on my screen in model space are rounded like in your picture. But when they print they look squared off. It seems the workaround for this is to join the curves which seems like another step that could be solved with printing option.
Hm - that should work as well
Print:
Can you run SystemInfo in Rhino and copy/paste the results?
Rhino 7 SR3 2021-2-8 (Rhino 7, 7.3.21039.11201, Git hash:master @ 7bcc02a54515376cb2bd3d05f62d9473ab4bc38c)
License type: Commercial, build 2021-02-08
License details: Cloud Zoo
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 64Gb)
Primary display: Intel® UHD Graphics (Intel) Memory: 1GB, Driver date: 10-14-2020 (M-D-Y).
Primary OpenGL: NVIDIA Quadro RTX 3000 with Max-Q Design (NVidia) Memory: 6GB, Driver date: 9-23-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 452.41
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-23-2020
Driver Version: 27.21.14.5241
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Users\ianmc\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.20335.757
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.3.21039.11201
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.3.21039.11201
Are you printing to Rhino PDF? I just saw another report about this recently
yes, and just tried with standard pdf option and got the same result
Shot in the dark would be to disable VIsualArq/Tibidabo in Options > Plug-ins page (close and reopen Rhino after) and see if that changes anything .
No luck
Hi Ian -
I’ll create a bug track item for that.
Edit - we have that issue on our list as item RH-50899
Thanks for reporting.
Hi Ian - yeah, we see it here too - it works with raster and not with vector printing - I had my settings on raster for some reason when I tested earlier. The developer is ‘on it’.
Thanks.
Thanks much!
Wim,
I am new to this forum so please excuse my lack of understanding of how this works. I clicked on your edit to item RH-50899 and took me to another page where it looks like you noted this issue was resolved. I opened Rhino today and updated to the newest version. I tried printing to PDF again and it appears the end caps are still squared off. Let me know if this is something on my end, or if the fix has not yet made it to the updates, or…Thanks much!
