Heyho.
Is there a tool in grasshopper (or gh-plugin) that works like cage edit in rhino? Please help. Thank you!
Why you need cage edit ? there are some components to morph objects
It works differently to the cage edit in Rhino (you don’t have to define internal points), but the Morpher component I posted here let’s you use any closed mesh as a cage to deform objects:
look at the point deform components and the spatial deform components.
Here I use nvrtices of BoundingBox as points for transformation, but any set of points can be used…
LikeCageEdit_01.gh (25.4 KB)
Hello. I tried out Redovan Grmusa script. Its really nice but is really slow trying to use a mesh. I reduced the mesh down by 90 percent and still … the script had big problems…
but thank you !!
