Is there any plugin for Grasshopper like this video?
Is there any plugin for Grasshopper like this video? I find it quite good and very convenient to use…
This is most likely done with Mesh Cage Morph.
Skeleton fattener + mesh cage morph - Grasshopper - McNeel Forum
Have a look at this thread:
Thank for sharing Martin~ :grinning:
Thank for sharing Daniel :smiley:
polysrf’s too? :pray:t4:
Cage morph is great - it is exacly what I needed to transform geometry defined along straight to curve while keeping its section vertical and keeping its projection to base line (flow doesnt’ do that)
Basic geometry:
Geometry cage morphed when geometry is close to 0,0
Geometry cage morphed when geometry it at coordinates are far away high ~7503300.0 x 5000000.0
Is this some precision issue in cage morph? Is cage morph using float?
For comparision FLOW component is working right on the same high coordinates.
Is the only way to solve this by moving objects to to 0,0 and back?
cagemorph_problem.gh (48.6 KB)
