why i didnt got my license key yet? i saw the one in the download page but it didnt work
Were you trying to download an evaluation version? The license key will show on the page after check the checkbox below
That is your license key, what about it doesn’t work?
hi, i alredy did that. but when i copy the license key to the designated area but it show that it is not valid.
Our records show you have a valid evaluation license which expires Oct 24, 2024.
It also shows that you have successfully added it to your personal Rhino account. All you need to do to is login into Rhino with the same email address
If you still have issues please reach out to support: Rhino - Rhino Support
ok. but when i download rhino and tried to open there is no option to log in and immediately an arror pops up that says there is no license connected to this rhino
Do you have other version of Rhino on the computer? Enscape installed? We’ve seen a few cases where the folder permission get off with this combination. The solution is to uninstall all these and delete any folders for each app. Then reinstall, starting with Rhino 8, then Enscape, Rhino 7 if need be.
Here are the folder locations for Rhino 8, the Enscape follow a similar pattern (Application Support)
Rhino 8 Mac license locations
- “/Users//Library/Application Support/McNeel/Rhinoceros/8.0/License Manager/Licenses”
- “/Users//Library/Application Support/McNeel/Rhinoceros/8.0/ra_cache.txt”
- “/Users/Shared/McNeel/Rhinoceros/8.0/License Manager/Licenses”
