Left-Side Context Menus for Right-Handed Pen Display Users
Hi McNeel team,
I would like to suggest an improvement to the positioning of context menus in Rhino, particularly for users working with pen displays and graphics tablets.
The problem
I use Rhino 8 on Windows 11 with an XP-Pen Artist 24 Pro pen display and a 3Dconnexion SpaceMouse.
I am right-handed and use the pen directly on the display for drawing, editing curves, selecting objects, and interacting with Rhino’s interface.
Unfortunately, when I open a standard context menu, it appears to the right of the cursor.
With a conventional mouse, this is usually not a problem. However, when working directly on a pen display, my right hand is positioned exactly where the menu appears.
As a result, my hand partially or completely obscures the menu entries.
To see and select the commands, I frequently have to move my hand or wrist out of the way, which interrupts the workflow and makes context menus unnecessarily difficult to use.
This is particularly inconvenient during precise curve editing and other repetitive modeling operations.
What I have already tested
I initially suspected that this was related to Windows rather than Rhino.
I therefore tried the following:
  • Changed the preferred pen hand to Right-handed in Windows 11 under Bluetooth & devices → Pen & Windows Ink.
  • Checked and adjusted the Windows registry setting MenuDropAlignment = 1, which is intended to favor left-aligned menus.
  • Signed out of Windows and restarted the computer.
  • Tested context menus with both the XP-Pen stylus and a conventional mouse.
  • Tested menu positioning in Rhino, Windows Explorer, and Notepad.
  • Tested the behavior near the center of the screen to rule out automatic repositioning caused by insufficient space near the screen edges.
Unfortunately, the context menus still open to the right of the cursor.
I also could not find an option in Rhino 8 to change this behavior.
Suggested improvement
It would be very helpful if Rhino offered a user-configurable setting for the preferred direction of context menus.
For example:
Options → Appearance → Context Menu Position
With the following choices:
  • Automatic – Use the default operating system or application behavior.
  • Open to the left of the cursor – Particularly useful for right-handed pen display users.
  • Open to the right of the cursor – Particularly useful for left-handed pen display users.
Ideally, this preference would apply to standard context menus throughout Rhino, including object-related and viewport context menus wherever technically possible.
Automatic repositioning near screen boundaries should, of course, remain available to prevent menus from appearing outside the visible display area.
Why this matters
Pen displays are becoming increasingly useful for CAD and 3D modeling, especially for workflows involving:
  • Tracing reference images
  • Creating and editing freeform curves
  • Organic modeling and surface design
  • Relief modeling
  • Direct interaction with control points and geometry
In these workflows, the user interacts with the screen physically, rather than controlling a cursor from a separate mouse.
This makes the direction in which a menu opens an important ergonomic and usability consideration.
For a right-handed user, opening menus to the left of the pen would keep the menu visible and accessible without requiring awkward hand movements.
The same principle applies in reverse for left-handed users.
Rhino 9
Since Rhino 9 is currently under development, I think this would be a valuable usability improvement to consider for the next version.
I would also be interested to know whether the current menu-positioning behavior is controlled by Rhino itself, the underlying Windows UI framework, or the operating system.
If this is already configurable through an undocumented setting, I would appreciate any guidance.
Would it be possible to introduce a left/right context menu positioning preference in Rhino 9, or potentially make it available in Rhino 8?
Thank you for considering this request!
Hi @Michael_Schirbel ,
Long time tablet user here and I have had similar wishes in the past. I was not able to get an option added to Rhino to control this in the past. I may however now be able to make a plugin that can help with this need. I’ll add it to my list :slight_smile:
