running the ‘layout’ command has been sporadically crashing files on this and the last service release. i type ‘layout’ and the program becomes unresponsive
Rhino 8 SR18 2025-3-17
Hi Daveed Kapoor,
Please run SystemInfo in the Rhino command line and post the results. Thanks!
Rhino 8 SR18 2025-3-17 (Rhino 8, 8.18.25076.15001, Git hash:master @ 49582fe32924623e5c8212768d1f6acbffaa7123)
License type: Commercial, build 2025-03-17
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A4000 (NVidia) Memory: 16GB, Driver date: 8-14-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.94
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 7-23-2021 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Brazil 2.0 for Rhino 6\Brazil.20.v60_x64.rhp “Brazil for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.18.25076.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.18.25076.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.18.25076.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.18.25076.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.18.25076.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.18.25076.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.18.25076.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.18.25076.15001
thanks - turned those plug ins off and so far no crashes. then i turned them back on because i need visualArq and Tibidabo - no crashes yet, though the problem has been sporadic. Hitting the + button on the view/layout tabs has been working fine the past few weeks, the crashes only come when i type ‘layout’
@daveed-kapoor do you get a crash dialog when Rhino crashes? If so, please send those in, as they’re very helpful in tracking down and solving crash bugs, thanks!
what will help in that case is to make a memory dump of the Rhino process. This is little bit more complicated though. It will generate a large file that you’ll need to zip and send us via file upload.
The process is explained here: Manually Creating a Memory Dump (DMP File) from an Unresponsive Rhino for Windows [McNeel Wiki].
