Layers Palette Freezes?
In the latest version of Rhino 8 (8.16.25021.13002, 2025-01-21) on macOS 114.7 (Sonoma), there seems to be a bug with the layer palette getting unresponsive after some time, at which point Rhino needs to be relaunched.
By unresponsive, I mean that you can still select the individual layers, but the little gizmos, like color swatch, lightbulb, lock, an so fourth, don’t react to any mouse button event/click any more.
It happened right after using PushPull a couple of times, but doesn’t seem to be exclusive to the latter.
Thanks for taking a look.
Hi Marc -
I’m not seeing such behavior on my end.
Which version of Rhino were you running before installing the January 21st version of 8.16? I can get you a link to the .dmg so that we can make sure that this is something that changed in Rhino at a specific point.
Unfortunately, I don’t remember.
Sure, thanks.
i have this issue for quite a while already. i am working on sequoia i am not sure when it started i also have the frequency set to candidate but it is there for a while, it happens often when i have rhino open for longer with files open, working on other apps then return at some time.
This morning, I’ve worked for about two hours on a hobby project in Rhino 8.15 and the layer palette again partially froze. The problem thus might be older than I previously believed.
As @encephalon already noted above, it might be linked to Rhino being open for some time and the computer going to sleep and waking back up, but the freeze definitely happens while working, not while Rhino is idle. This time I noticed it right after doing surface trimming for a failed edge fillet of an exploded brep.
Sorry, but I haven’t got any clue, what triggers this. I can’t see any distinct pattern yet.
Have a nice weekend y’all! And thanks for caring.
Sorry for the necro-bump, but this exact issue also happens to me a lot.
Do any of you still encounter this problem ? I’m currently on rhino 8.25 with macos sequoia, but it also happened on previous 8.xx versions.
Please let me know if this topic has already been discussed somewhere else.
  • Noam
I’ve also encountered it a couple of times since my last post. For me, it’s still hard to say what causes it.
Hi Noam -
Is this something that you can reproduce at will or is this something that just happens once in a while?
No it’s impossible to reproduce, it just happens from time to time. But on long sessions, it’s almost certain that the bug will occur. I’m creating a new layer and suddenly I can’t rename it, or I can’t turn it off, but not all layers are necessarily frozen.
Hi All,
I believe a fix is coming - just need to do some more testing.
– Dale
For some reason, this bug has been more frequent recently. Perhaps since the MacOS Tahoe update?
I have had this issue aswell and only on Rhino 8
First I thought because my PC was old but it seems it’s not the case here
Difficult to reproduce as it comes randomly
