Layer State Problem
The files attached contain geometry extractedd from a large file I cannot share. It has started as Rhino 7 file but I saved it as Rhino 8 today.
I saved two layer states but the layer state manager somehow seems to be broken in Rhino 8 with this file.
I’ve saved the Rhino 8 file backwards as Rhino 7 file and opened it in Rhino 7. The layer states work fine.
layer_state_problem_7.3dm (134.2 KB)
layer_state_problem_8.3dm (134.2 KB)
Got it. Thanks. I created a youtrack RH-76102
The fix is in, check tomorrow’s WIP by running _GetIssueState for RH-76102
https://mcneel.myjetbrains.com/youtrack/issue/RH-76102
Thank you!
