Hello!
I noticed some keyboard shortcuts have been added to the new layer panel:
That’s pretty cool! Yet I seem to be too stupid to invoke them. When the menu is open and I press any of these keys (S, N, U, …), it is written to the command line, and nothing else happens. Same when the menu is closed and I’m just hovering over the panel, pressing a key.
Is this w.i.p.?
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9181.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2060 SUPER (NVidia) Memory: 8GB, Driver date: 10-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.01
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2023
Driver Version: 31.0.15.4601
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.15
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 22GB, Driver date: 12-1-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.99
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 12-1-2023 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
Driver Date: 12-1-2023
Driver Version: 31.0.15.3799
Total Video Memory: 23028 MB
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\KeyShot9RhinoPlugin (ecfe8d1f-876a-460f-aa5e-3dd816936811)\1.0.0.0\KeyShot9RhinoPlugin\Rhino 5.0\KeyShot9RhinoPlugin.rhp “KeyShot9RhinoPlugin” 1.0.0.0
C:\Users\martinsiegrist\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
Anyhow, these would be a welcome addition! Keep them coming, please…
Would you consider the possibility of invoking them just by hovering over the Layer panel (without the necessity of opening the menu)? Context sensitive shortcuts, practically (one of the UI goodies of the great Softimage XSI, back then, which was renowned for it’s particularly well designed UX).
I’m aware that might feel disruptive for those of us used to the fact that any keystroke is sent to the command line. However, after some adapting, this can be a real booster…
I’ve been wondering about these shortcuts too since I noticed them recently, glad I found this topic. I would have never guessed that you’re supposed to RMB layer to open the context menu and then hold RMB again and press the desired key.
I support @Eugen’s suggestion that it would be great if you just selected the layer and while having the mouse still over the layer panel, pressing the key would call up the function. Although I am also slightly worried that it could be then triggered accidentally when trying to type commands.
So what about a compromise - you’d still have to open the context menu but then you would press the key directly without having to hold RMB? This shouldn’t cause any accidents.
I’d also love to have a shortcut for “Change object layer”.
By the way, context sensitive shortcuts are there already - Delete key deletes selected object if mouse cursor is over a viewport or a layer if you move the cursor over the Layer panel. And yes, numerous times I’ve accidentally deleted a layer instead of an object (or was met with a warning I’m about to delete one that contains objects) but I don’t complain. But I admit that with letter keys it would be probably worse.
I also have those shortcuts, i would not mind at all if the Delete Function now is not possible by pressing “DELETE”. I have to right click and manually select delete, which is something I do not enjoy at all
Any chance to manually change the shortcut for delete back to what i was before?
BR/Sebastian
