Layer panel glitch
Lately, I’ve noticed that the layers panel scrolls by itself when hovered over.
It searches, as it were, for the first layer selected ?
I think it is a issue…
Regards
Yep. It does it vertically and horizontally. I’ve undocked my panel and added a button to my middle mouse button menu for the “Layer” command. So I just close the dialog when not in use and re-open it. It doesn’t cure the issue but if you work with a larger dialog it alleviates the issue. It can’t jump if it can’t scroll.
Thank you keithscadservices for the suggestion.
Could someone at McNeel acknowledge this problem, please?
Steps to reproduce the issue:
Create 20 layers (more than the panel can show)
Select Layer 01 (first/top)
Scroll down to make the selected layer disappear.
Move mouse outside of the panel and come back.
Hi @lahos,
This is a know issue, unfortunately. I’ve pushed a fixed in to this week’s 8.18 release candidate that should mostly fix this.
– Dale
