Lattice structure for shoes
Here some render of lattices for shoes.
Disclamer : I am not a shoe designer. I don’t think open lattice are good for shoes … But i was a good exercise to answer this question
To do that I reuse a model of feet that was on this forum.
The I remesh it using the Quad remesher form Rhino 7 WIP
I used this clean mesh to extract the insole, here I used my Mesh Iso Splitting Script with a single angle.
This mesh is quad remeshed in order to get the quads pattern that will be used for the lattice
This upper part of the insole is extruded with a variable thickness depending on X
These 2 quad meshes are used by Pufferfish plugin to make the boxes
Lattice from Intralattice is morphed in Pufferfish boxes
For rendering I used my own Mesh Pipe has classical Mesh Pipe (form PufferFish) are not fast as the output one mesh per curve.
These meshes are not usable except for rendering. To thicken the mesh use Dendro and/or fattener
20200506_shoe.gh (338.1 KB)
at least the mesh is useful for future tests
:smile:
You need Rhino V7 !!! for Quad Remesh
cool
however this message appears
This is really great stuff. Quad remesh makes all the difference. You could also try using the minimal surfaces in the mesh+ plugin for the cell structures. Could make some really interesting lattice structures. :slight_smile:
@vikthor the message is due to the fact that I used Rich Graph Mapper from Daniel González Abalde
It had some nice possibilities to legacy Graph Mapper
@Andrew_Schiffer thanks for the advice, for sure Mesh+ adds some very nice lattice
20200507_shoe.gh (406.5 KB)
HI @laurent_delrieu do you have any solution to use the MESH+ if we are using Rhino on Mac ???
It should work fine on Mac. They are user objects, make sure they go into the user objects folder.
Hi @Michael_Pryor thanks I Try it. it’s working.
Many thanks
Hi Laurent Delrieu
There was a problem reading the file, is it a problem with my rhino version?
Read the discussion. If you don’t find answers, copy the messages in red component and provide the information on your rhinoceros
Hi Laurent Delrieu
Thanks for your quick reply
I checked the error message as follows: (Chinese)
I am using rhino 6.0, is this the problem?
Gavin
Yes you need rhino 7 wip or rhino 7 beta
hello my feriends i want [
General Lattice Studio for rhino 6
Kind of like this?
tank you friend
Hi Laurent,
I can’t read the file properly because I’m missing some property rights? I have installed all the plugins described here and I have problems with both Rhino 7 and Rhino 8. What is the reason?
Hello
I have the same problem.
it is easy to cure.
Go on the component, double click on it and add
Imports Microsoft.VisualBasic
in the white part
Then compile (click on green triangle)
20200507_shoe.gh (414.3 KB)
Nice, thank you very much. I got it working and it works :slight_smile:
