Latest update immediately crashing when opening document 8.0.22032.16306
Hi
Just updated to the latest WIP and rhino is immediately crashing when trying to open either a new doc or a previous one with just one sphere
There were no crashes at all until this latest update.
Version 8 WIP (8.0.22032.16306, 2022-02-01)
the only change in my computer was this latest update
thanks a lot
Akash
If you get the crash log maybe post it here?
I just updated to that WIP verison and it starts fine on my M1. I am able to create new documents and open existing ones, even those with Raytraced active.
Hi
discourse won’t allow sending the report here.
I have sent through the crash system 2 - 3 times yesterday, I can send more if needed.
I’m on an intel 2013 MBP,
thanks a lot
Akash
Save it as a text file, then attach the file
here’s the report
thanks
crash report akash.rtf.zip (79.5 KB)
A bit hard to tell for sure but have you tried with disabling the Metal test code?
Perhaps something changed in Metal that is crashing [it was always on and stable until now] But to disable Metal… I’ll have to find a way to open a document first. [unless you have an under the hood way to do that?]
thanks a lot
Akash
Just to make sure, Akash, does Rhino 7 still run as it should?
Hi Wim
Yes 7 is fine [I’m holding off updating it for now, so it’s on 7.15.22011.07002
thanks a lot
Akash
Just to add that I also tried to open a v7 file in the WIP by assigning the file type to the WIP and clicking on the file instead of starting the WIP first [splash screen] It Crash all the same.
thanks a lot
Akash
Would it be possible to send me a link to the previous build, [until the crash issue with the current is resolved ?]
thanks
Akash
Just install 8.0.22039 the crash still happens on WIP file opening [attached. is the crash report]
WIPcrash8.0.22039.rtf.zip (68.0 KB)
Here’s the system info:
Summary
Rhino 8 SR0 2022-2-8 (Rhino WIP, 8.0.22039.16306, Git hash:master @ 87849b22f579aaae10cec6e276a54584f9910630)
License type: Commercial, build 2022-02-08
License details: Cloud Zoo
Expires on: 2022-03-25
Apple macOS Version 11.6.2 (Build 20G314) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro11,3
Language: en-IL (MacOS default)
NVIDIA GeForce GT 750M OpenGL Engine (OpenGL ver:4.1 NVIDIA-16.0.13 )
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 2 GB
Graphics: NVIDIA GeForce GT 750M
Displays: Color LCD (221dpi 2x), W2261 (102dpi 1x)
Graphics processors
Intel Iris Pro (1536 MB)
NVIDIA GeForce GT 750M (2 GB)
Color LCD (1440 x 900)
W2261 (1920 x 1080 @ 60.00Hz)
USB devices
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
3Dconnexion: SpaceMouse Enterprise
Wacom Co.,Ltd.: Wacom Intuos Pro M
Bluetooth devices
Apple: Apple Magic Mouse
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.22039.16306
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.22039.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22039.16306
/Applications/RhinoWIP.app/Contents/PlugIns/Connections.rhp “Connections” 8.0.22039.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConnectionsUI.rhp “ConnectionsUI” 8.0.22039.16306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.22039.16306
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.22039.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.22039.16306
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.22039.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp “RhinoCPython” 8.0.22039.16306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.22039.16306
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.22039.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.22039.16306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.22039.16306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22039.16306
Thanks a lot
Akash
Hi Akash -
A few more questions…
Do you remember if you had enabled TestMetal before installing the version that crashes on your system?
OpenGL issues are often the cause of Rhino crashes and, on Mac, they are typically resolved by updating the Operating System. Can you update your Mac to a more recent macOS?
You didn’t specifically point to a previous WIP that worked - here’s a link to the 2022-01-18 version. It’d be interesting to see if that one runs.
Most likely it was enabled, but I’m not fully sure [made a button to switch it off and on quickly when there’s a display issues and I often toggle it]. *Edit : Just installed the older version and files opens without a crash. and yes Metal was on.
I think I can update to Monterey… It such a [good] old computer, that I wasn’t really going to update it any more. But if that is necessary to run the WIP…? I can try.
thanks a lot
Akash
Hi -
I think that might be worth a try. Make sure to create a Time Machine backup so that you can go back if necessary.
The alternatives are waiting and hoping that this gets fixed all by itself - there is always that possibility but definitely not guaranteed. I had been crashing new WIPs on startup for a while and that went away…
… or trying to bisect the issue to find out which change started crashing on your machine. That is a potentially long drawn process as there are more than 40 different builds between the versions that are now known to be good and bad… (And, as in my case, not necessarily an outcome that clearly points to a cause.)
Hi Wim
the latest build that worked for me was just 2 builds ago. [meaning the last 2 builds were crashing and the one before that was totally fine…!
there was a security+ update to BigSur just now that I installed. I’ll try updating the WIP on it first. Do you think it is better to toggle Metal off before updating?
*Edit: updating to latest WIP, it still crash. [but forgot to disable Metal before update]
thanks a lot
Akash
Hi Akash -
Not really. It was just 2 public builds ago. There are several internal builds every day.
Hi Wim
the Crash is still present in today’s Wip 8.0.22047.04306.
is there really nothing that can be done, short of upgrading to Monterey …? [I’m up to date in Big Sur 11.6.3]
thanks a lot
Akash
Fired up the WIP today and I’m getting the same crashes - as soon as I open a file or create new from a template. Not sure when I tried the WIP last (it has been a while). Upgrading to Monterey isn’t an option for me - my old iMac won’t update beyond Big Sur.
Another oddity, I’m not getting any crash reports. Something else to look into later - any suggestions on what/where to check?
Tried rolling back to the version posted above:
No help - same crashes.
Here's my SystemInfo
Rhino 8 SR0 2022-2-16 (Rhino WIP, 8.0.22047.04306, Git hash:master @ 2ba658f38e2b55a026cc6bd1e6910b67fae831ab)
License type: Commercial, build 2022-02-16
Expires on: 2022-04-02
Apple macOS Version 11.6.3 (Build 20G415) (Physical RAM: 32Gb)
Mac Model Identifier: iMac15,1
Language: en-US (MacOS default)
AMD Radeon R9 M295X OpenGL Engine (OpenGL ver:4.1 ATI-4.6.21)
OpenGL Settings
	Safe mode: Off
	Anti-alias mode: 4x
	Render version: 4.1
	Z-Buffer depth: n/a
	Total Video Memory: 4 GB
	Graphics: AMD Radeon R9 M295X
	Displays: iMac (173dpi 2x)
Graphics processors
	AMD Radeon R9 M295X (4 GB)
		iMac (2048 x 1152)
USB devices
	Apple Inc.: FaceTime HD Camera (Built-in)
	Hewlett-Packard: HP LaserJet P1006
	Wacom Co.,Ltd.: Wacom Wireless Receiver
Bluetooth devices
	Apple: Apple Wireless Keyboard
	Apple: Apple Wireless Trackpad
	None
Third party plugins
	/Users/Kevin/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot9Plugin.rhp/libkeyshot_rhino_plugin.dylib
	/Users/Kevin/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/KeyShot9Plugin.rhp	"KeyShot9RhinoPlugin"	1.0.0.0
	/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	8.0.22047.4306
	/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	8.0.22047.1002
	/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp	"RhinoRoslyn"	8.0.22047.4306
	/Applications/RhinoWIP.app/Contents/PlugIns/Constraints.rhp	"Constraints"	8.0.22047.1002
	/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConstraintsUI.rhp	"Constraints UI"	8.0.22047.4306
	/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	8.0.22047.4306
	/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	8.0.22047.1002
	/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	8.0.22047.4306
	/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	8.0.22047.1002
	/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp	"RhinoCPython"	8.0.22047.4306
	/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	8.0.22047.4306
	/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp	"Displacement"	8.0.22047.1002
	/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	8.0.22047.4306
	/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	8.0.22047.4306
	/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp	"RhinoCodePlugin"	8.0.22047.4306
I’m hoping to hold off on upgrading to a new mac until the new Apple silicone is a bit more mature. Hope this won’t prevent me from running Rhino V8 when it’s released.
-Kevin
Rhino 8 will run on both Intel based and Silicon Macs
