laptop Iris is working on 5 not 6 I started 5 first after the
install. and started 6 first n the desktop that is where Iris is working
on each computer
on each computer
Can you please post the logs as you had done before with the instructions from @will?
Hi Luis,
Itās working as expected here! For both versions iris installed correct!
Thanks
-Willem
Desktop all logs with todays date from both 5 + 6
iriswin(1) (20170918-123850)desk.zip (12.2 KB)
InstallPackagesForRhino (20170918-124002)_desk.zip (1.94 KB)
Hi @fishtriangles. Thanks for the logs. Iāve been looking into the laptop situation⦠It appears that the correct version of the plug-in was installed and registered for Rhino WIP, so weāll need some more information to figure out why itās failing to load. Iāve put together some troubleshooting steps below.
First, the easiest option. There was a new Rhino WIP released yesterday. Please give that a try. If it doesnāt magically resolve the issue, then continue belowā¦
Next, please remove all the old version of Iris and try installing again.
Close Rhino, navigate to %APPDATA%\McNeel\Rhinoceros\6.0\Plug-ins and delete the folder named āIris (1cd9c8f5-c901-426c-8e80-d6a2e2b18bba)ā. Then try installing the latest Iris RHI again.
If this doesnāt work, would you mind trying to load the plug-in via dragānādrop? This will effectively remove the Rhino Installer Engine from the process, helping us to isolate the problem.
If Iris loads correctly, then Iād like to double check that the RHI is registering the plug-in correctly.
HKEY_CURRENT_USER\SOFTWARE\McNeel\Rhinoceros\6.0\Plug-ins\1CD9C8F5-C901-426C-8E80-D6A2E2B18BBA
, using the tree view on the left1CD9C8F5-C901-426C-8E80-D6A2E2B18BBA
node in the tree view and choose export, then change the format to text file)If you can send the .txt export to via direct message (there shouldnāt be any sensitive data, but Iām just being careful) Iāll have a look to make sure that the correct version of the plug-in was registered.
I went through it all,on the laptop. The drag and drop worked. I
restarted 6 and it loaded on its own, with no messages on 5 or 6
I tried it on the desktop in 5 but it still said this version of Iris
has expiredā¦
Thanks,
@fishtriangles what version of Rhino 5 service release do you have? As stated here, you need at least Rhino 5 sr12. Is the message you are seeing that Iris is out of date, or that you need to update Rhino?
Rhino Plug In Error Iris.Win.Rhp This version of Iris has expired. Please visitā¦
Version 5 SR14 64-bit
(5.14.522.8390, 22-May-17)
I get the same error that Iris is out of date even though I downloaded it 10 minutes ago.
@fishtriangles I just re-read the logs and caught something that I missed before. The version of Rhino WIP on your desktop is over a month old (6.0.17220.11131, August 8, 2017). Iāve already fixed the bug that is preventing Iris from being installed for Rhino 5 (64-bit) SR14. Updating Rhino WIP to the latest build should solve your problems on this machine.
Hi @Joseph_Culbert, could you provide some more information? Iād be very interested to see the log from the latest attempt to install Iris. You can find this in %APPDATA%\McNeel\Rhinoceros\5.0\logs (replace ā5.0ā with ā6.0ā if you have Rhino WIP installed).
Will,
The first time I installed by dbl clicking the .rhi file. When I opened a new instance of 5.0 I got the error. I read here someone mention drag and drop so I tried that on an open 5.0 and got a message that Iris was sucessfully installed. But when opening a 5.0 instance got the same error as before.
iriswin (1) (20170920-144549).zip (2.7 KB)
Did you drag and drop the RHI file, or the Iris.Win.rhp file thatās inside the RHI? (Note: the RHI is just a renamed ZIP.)
It seems to be working now in V6 fine. Iāll look and see what is in the zip.
Glad itās working in the WIP for you . If you wouldnāt mind sending over the latest log for Iris in %APPDATA%\McNeel\Rhinoceros\6.0\logs too, Iād be interested in having a lookā¦
Is this what you need?iriswin (1) (20170920-130256).zip (3.3 KB)
Thatās the one. Thank you. Unfortunately I canāt see a reason for Iris not to load in Rhino 5.
I appreciate your help so far. As Iām sure you can understand, itās difficult to resolve these issues when we canāt reproduce them on our own machines!
Iām curious to know which version of Iris is registered for Rhino 5. Are you familiar with the Windows registry?
Registry is above my paygrade! Thanks for your help and maybe having Iris working in v6 will encourage me to spend more time there. I might have a look at the registry as you suggest.
No worries. Thanks for digging into this with me.
