I am trying to generate some curves in a “For” loop, then select them all and add them to a group, but it seems that Rhino.LastCreatedObjects does not work in the same script. I took the example from Help and added a for loop to generate same curves after the circles and yet the 3rd circle is being selected.
Thank you very much!
Cristina
Call Main()
Sub Main()
Dim arrObjects, strObject, arrCrv(5), i
Rhino.Command "_-Circle 0,0,0 10"
Rhino.Command "_-Circle 10,0,0 10"
Rhino.Command "_-Circle 20,0,0 10"
For i=0 To 2
arrCrv(i) = Rhino.AddLine(Array(0, i, 0), Array(10, i, 0))
Next
arrObjects = Rhino.LastCreatedObjects
If IsArray(arrObjects) Then
Rhino.SelectObjects arrObjects
End If
End Sub
Hi @cristina.b,
the method Rhino.LastCreatedObjects
will only get the objects created using Rhino.Command
and should be run right after using it.
You might select all the objects easier if you apply them to variables like below:
Option Explicit
Call Main()
Sub Main()
Dim i, arrLines(2), arrPlane, arrCircles(2)
For i = 0 To 2
arrLines(i) = Rhino.AddLine(Array(0, i, 0), Array(10, i, 0))
Next
arrPlane = Rhino.WorldXYPlane()
arrCircles(0) = Rhino.AddCircle(arrPlane, 10)
arrPlane = Rhino.MovePlane(arrPlane, Array(10, 0, 0))
arrCircles(1) = Rhino.AddCircle(arrPlane, 10)
arrPlane = Rhino.MovePlane(arrPlane, Array(20, 0, 0))
arrCircles(2) = Rhino.AddCircle(arrPlane, 10)
Rhino.SelectObjects arrLines
Rhino.SelectObjects arrCircles
End Sub
to get lines and circles into a single variable, you could use Rhino.JoinArrays
like this:
Dim arrObjects
arrObjects = Rhino.JoinArrays(arrLines, arrCircles)
c.
It works! Thank you very much!
