First try in really trying to write a script and I’m stuck on something that is probably obvious.
How can I group the created objects at the end of the script? any tips would also be appreciated. thanks in advance.
import scriptcontext as sc
import Rhino
def AddBalloon():
# some constants
radius = 0.25
fontSize = 0.125
fontOffsetDist = 0.1
printWidth = 0.60
# draw leader line
LeaderPoints = rs.GetPoints(
True, False, "Select leader LeaderPoints")
rs.AddLeader(LeaderPoints)
point = LeaderPoints[-1]
rs.EnableRedraw(False)
# draw circle
circle_id = rs.AddCircle(point, radius)
rs.ObjectPrintWidth(circle_id, printWidth)
# hatch circle
newHatch = rs.AddHatch(circle_id)
rs.ObjectPrintColor(newHatch, (255, 255, 255))
# find number
findNumber = rs.GetString("Enter part find number:")
# quantity text
partQuantity = rs.GetInteger("Enter part quantity:")
if partQuantity > 1:
# add part quantity and midline
circleEndPt = rs.CurveEndPoint(circle_id) # get circle end point
circlePerpPt = rs.Polar(point, 180, radius) # create perpendicular point
midLine = rs.AddLine(circleEndPt, circlePerpPt) # create line
rs.ObjectPrintWidth(midLine, printWidth)
rs.SelectObject(midLine)
rs.Command("_BringToFront _SelNone")
upperTextPoint = rs.Polar(point, 90, fontOffsetDist)
rs.AddText(findNumber, upperTextPoint, fontSize, justification=2 + 131072)
lowerTextPoint = rs.Polar(point, 270, fontOffsetDist)
rs.AddText(str(partQuantity) + "X", lowerTextPoint, fontSize, justification=2 + 131072)
rs.EnableRedraw(True)
else:
rs.AddText(findNumber, point, fontSize, justification=2 + 131072) # only add find number
AddBalloon()
