Hello Guys, Ive checked many related posts and topics related to the image sampler , anyhow could nt fix a specific image size problem which ive stumbled right now
So the surface which the image has to be projected / a perforated pattern applied is of dimensions 120x4m , and ive made a custom image for this size
However on generating a gradual circle pattern on the values , i am not sure how it is to be done
you have -conveniently- reparametrized the Surface Domain, which is now set to “0 to 1”, so all the UV points are generated in the same “0 to 1” Domain
this means that the image needs to be set the same way, otherwise you are sampling a smaller portion of it (in particular you were sampling all the points in a portion that was 1/120th wide and 1/50th tall)
in this text panel you can write the range of radii, from diameters that corresponds to black points (brightness value = 0) to diameters that correspond to white points (brightness value = 1) like “minimum_radius to maximum_radius” (in this case it’s 0.01 to 0.05 units)
consider that the behavior of the function that relates brightness and circle radii is now linear, but you can pass it through a Graph Mapper to make it behave however you might like
