Greetings,
I try to do a Radiation Analysis of one level of a building, full year, with interior rooms and balconies. But the Radiation component takes 15 minutes to compute! And the offset distance is 2000mm - I need it less.
Any tips on how to reduce the compute time??
Here’s my grasshoper and the results:
Thank you!
Hi @Bogdan_Chipara,
That does not appear to be your bottle neck as the ms stands for milliseconds so that component is taking 15milliseconds to compute not 15 minutes.
If you’re script has a bottle neck that IS taking 15 minutes it’s somewhere not shown on this canvas screenshot as I see 6.6, and 4.5 seconds, and then 37, 15, 12, 9 ms.
so you should be getting results in a little over 11 seconds here…
Well… I see that you have the radiation component set to False so likely when that is enabled you do have a bottleneck there…
Please share the script with internalized geometry/data if you want more help identifying a specific bottleneck.
Hope that helps!
@michaelvollrath , thanks for your reply!
- your observation is correct, once set to True, radiation will run for 15minutes.
File is to big, you will have to download from Wetransfer:
You also have the EPW file in the archive.
Let me know how it runs on your end.
Thanks for sharing @Bogdan_Chipara,
I’ll try and take a look today and report back
