Label points in sequence with numbers?
Hi wonder how I could label points with numbers (for print) from 1, 2, 3, - 350 and aligning outwards from the points, (like in the screendump). And yes its for stringart :slight_smile: . Dont know how to make it in grasshopper? Any hints much appreciated !
StringartTest_01.3dm (123.5 KB)
@Per
This is how I would do it.
The text is an outline for now, you might adapt that.
I took the circle from your file and divided it.
TestArrayTexts.gh (10.1 KB)
Here is part of the solution possibly. I the text orientation does not work quite right with the vectors. One of the other guru’s will likely have a better idea.
curve.gh (12.8 KB)
curve2.gh (44.7 KB)
Looks like it needs half of the planes to be flipped?
Yes, I was in a rush.
@tobias.stoltmann @Brad_Shipton @René_Corella Finally back in front of my computer once more and find your posts, so happy! Thank you so much guys! Can not mark all your definitions as solutions but happy they all worked and I get to learn something new, again! Cheers, Per
