Knife bug/fail
Knife fails here if I snap to the curve. In the video, I choose the knife tool, select the subd (FacesToSplit=All) in the right ortho view, then snap to the line to do the cut. No cut happens. Then I try it again without snapping and the knife tool works as expected but not exactly where I want.
knife fail.3dm (43.7 KB)
try moving the curve you are snapping to in front of the geometry you are knifing… that works here.
It works if I flatten the curve (can be in front or behind the subd, but the curve has to be flat?)
@pierrec could elaborate on the intricacies of this.
I’m just the “figure out how to workaround it” guy…he’s the “actually fix the underlying problem” guy.
Looks like a bug in how Knife preprocesses the pick points. Tracking it here: RH-100065 Knife: Picking points on a curve not aligned with the view confuses the intersector
Thanks for the report, @phcreates
