Qualcuno che si intende di Karamba 3d, può aiutarmi a risolvere un problema relativo all’inserimento dei Loads nel modello strutturale??
Hi, can you please write your question in English as I do not understand the translation from Google Translate
Hi Matthew,
I was wondering if someone knows the use of Karamba 3d, because I’m having some problems assembling the model when I have to put the Loads.
I am designing a roofing, therefore structure load (cladding), wind load, maintenance load
Hi @valeriasorb,
can you be more specific or provide a script so we can help you? Usually you can apply this as either line loads or mesh loads using different load cases.
I solved the problem. Thanks anyway
