What to put in ForceDirs to get the stresslines? And yes I have a license of Karamba.
Is this the right place to ask questions about Karamba?
I cannot find any example that explains me what to input ForceDirs with, all examples I found are old.
It is not that I am just asking and not studying Karamba, it is just because I really do not know, still.
Hi @ForestOwl
you need to simply input a vector in the ForceDirs plug. If you hover over the plug a hint appears as to what type of data it accepts. Also more information can be found on page 100 of the Manual found on our website.
If you select Cross Section in the Render Settings of the Shell View component you will see three meshes - the axis mesh and the outer faces of the mesh.
I am not sure what you mean by the yellow banana. If you turn off deformation you will see the original mesh with the two outer meshes which have a “thickness”. The varying thickness is a result of the cross section optimization. You can increase the domain of the shell thicknesses by tweaking the domain that you defined as the cross section dimension. The orange output simply says that the structure is currently overutilised with the current setup. You can look into increasing the shell thickness or the material properties.
