Karamba Line Joint bug
Hello! In previous version you fixed the bug with Beam-join-agent component. But you didn’t fix the same issue in Line joint component. The screenshot shows that we supply a stiffness of 2500 kN/m to the input of the component, and the output of the component is 6 times greater.
Also, the previous version did not fix the graphical problem of displaying the stiffness of the Beam-join-agent component. The screenshot below shows that 2500 kN/m of stiffness is supplied to the component input, but in the graphical interface it is displayed as 2.5
Best regards,
Ekaterina Strelnikova
Hello @Strelnikova,
thanks for your bug-report and sorry for the inconvenience!
I will fix that a.s.a.p. and give you notice when it’s done.
– Clemens
Hello @Strelnikova,
I have fixed the bug and sent you a link to the new version.
I hope that solves the problem.
The bug-fix will be part of the next service release of Karamba3D.
– Clemens
