Hello, I need these two sagging beams, which are defined as 2field beams with an articulated support on top of the column head 1. I tried to establish a connection between this component by using the JoinAgent and contracting the identifiers. but somehow that doesn’t bring the desired result.
So I tried to provide the curve with a control point in the middle, but the program then turns it into 4 beams instead of the 2 I want.
Does anyone have an idea about this?
Thank you very much
But then, when I apply the next elements to the struct, unexpected behavior occurs. these elements need a parabola as a moment progression, but some of them are linear… And then as soon as I deform the display more or activate the elements via the render settings of the beam view, the model is out of the viewing area
Hello @Kevin_Scholtyssek,
my first guess is that some parts of your structure are kinematic.
You can check whether the model consists of one piece using the “Connected Parts”-component. Another possibility to detect rigid body modes is to do an Eigenmodes analysis (see here).
– Clemens
can you share your definition as its hard to troubleshoot from just the video
Internalized Data.gh (196.0 KB)
thank you for your help, i will look up the eigenmode analysis…
