Karamba Isotropic Material
Hi everyone,
I want to conduct a Karamba FEM analysis with an isotropic material. I have the specs table for material that I want to use. However, I don’t know how to match the specs with the related component of Karamba. Can you help me, please? Do I need to have any other specs to get the correct result?
Thanks in advance,
Ekran görüntüsü 2024-04-13 220000
if you hover over the inputs you can some hints
Youngs Modulus = E = Elastic modulus
Shear Modulus = G
Specific weight = density
tensile strength = yield strength (unless stated otherwise)
compressive strength = negative yield strength (unless stated otherwise)
Thank you.
