Kangaroo Simulation issue for multiple lines and surface
Hi, I am new for Grasshopper forum. I wants to use lines interconnected at circle nodes for Kangaroo simulations. If i used all lines and apply load then results are not supportive. only solution is to generate lines from surface. in such case mesh would be uncontrolled shape (neither triangular nor quadrant). hence Is there any way to keep line as part of mesh and run simulation for further use. I got help from few members earlier
Polygon Mesh Maker - II for Support.gh (24.6 KB)
but if someone has any idea to resolve such issue. We prepared one more script but still members are stretching and not maintaining smooth curve of catenary lines.
crossing_hang.gh (14.8 KB)
Polygon Mesh Maker - II for Support Edited V0.gh (79.0 KB)
Thanks for Reply. but It has same issue. If you look at closely lines are not smooth, due to rigidity of members based on length and joinery, I Believe.
